Uniquely identifying auth requests from l2tp/ipsec clients
  • 1.  Uniquely identifying auth requests from l2tp/ipsec clients
    Posted Apr 03, 2013 09:28 AM
    I'm  looking at using one of our Aruba controllers to provide an l2tp/ipsec service for network staff  who need to have unfettered access to our network from outside our network. Back end auth is against our RADIUS service and I'm generating a specific Filter-Id radius attribute to indicate that they're l2tp/ipsec users. A successful auth then places them in a specific role and away they go.
    My concern however is that I've set up the correct Filter-Id attribute value. The radius server copes with eap and mschapv2 auths from all over the place and may well have Service-Type=Login-User from other devices
    Looking at the the RADIUS Access-Request packet sent by the controller, I've got
    NAS-IP-Address -- <ip address of controller>
    NAS-Port = 0
    Nas-Port-Type - Wireless-802.11
    User-name - me
    Calling station id - 000000000000
    Called-Station-Id - mac address of client
    Framed-ip address - ip address of client machine
    MS-CHap stuff
    Service-Type - Login-User
    Aruba-Location-Id - "N/A"
    Aruba-AP-Group - "default"
    Message-Authenticator - <stuff>
    At the moment I'm checking for my username, the Aruba-Location-Id, the Aruba-AP-Group and the Service-Type but I'm not entirely convinced that the combination of those 3 uniquely identify an auth request associated with an l2tp?ipsec connection.
    Any way of really really identifying the auth request as being associated with an l2tp/ipsec connect request? Can I add an atribute at the controller end to say this is an l2tp/ipsec auth request?
    Rgds
    Alex
  • 2.  RE: Uniquely identifying auth requests from l2tp/ipsec clients
    Posted Apr 03, 2013 09:34 AM
    Nas Port type should be VPN or Virtual for VPN authentication.
  • 3.  RE: Uniquely identifying auth requests from l2tp/ipsec clients
    Posted Apr 03, 2013 09:44 AM
    Would be good if it was but  it's set to Wireless-802.11
    We've got a whole batch of RAPs out there as well
    Rgds
    Alex
  • 4.  RE: Uniquely identifying auth requests from l2tp/ipsec clients
    Posted Apr 03, 2013 10:14 AM
    If you have RAPs along with VPN clients, I suggest you open a support case so that you do no break anything with your RAPs.
    If you are running ArubaOS 6.x, in Security> Authentication> L3 Authentication there are different ways to handle authentication depending on if it is a RAP, or incoming VPN connection.
  • 5.  RE: Uniquely identifying auth requests from l2tp/ipsec clients
    Posted Apr 03, 2013 10:22 AM
    Sounds like a good idea. FWIW once I've authenticarted over an l2tp/ipsec connection and have a look at the clients that are loggged on, I can see that my auth type is VPN
    and yes, we're running ArubaOS 6.1.3.7
    Rgds
    Alex
  • 6.  RE: Uniquely identifying auth requests from l2tp/ipsec clients
    Posted Apr 03, 2013 10:27 AM
    Allright.
    Your 802.1x clients have a server group.  In Configuration> Security> authentication> L3 Authenticatin> VPN, THAT has a server group.
    You could create a new server that is the exact duplicate of your 802.1x server, except you add a parameter in the NAS-ID, like VPN.  Create a new server group, and add that server to it.  Replace the server group in Configuration> Security> authentication> L3 Authenticatin> VPN with that new server group.  On your radius server, the NAS ID of VPN will let you know that it is an incoming VPN connection.
  • 7.  RE: Uniquely identifying auth requests from l2tp/ipsec clients
    ust read your message again. Already set up the rught stuff in the layer 3 auth. There are 3 profiles there, default, default-cap anbd default-rap. I've pointed default at our radius servers and left the default-rap alone so they're stil running o.k.
    Rgds
    Alex
