Upgrade 650 Controller from 5.0.2.0 to 5.0.4.115.
  • 1.  Upgrade 650 Controller from 5.0.2.0 to 5.0.4.115.
    Posted Feb 27, 2014 01:03 PM
    I am going to upgrade our controller from 5.0.2.0 to 5.0.4.115, but I don't see anything within the release notes about needing to upgrade to an intermediate release.  Is that the case? Can I upgrade directly from 5.0.2.0 to 5.0.4.115 without any issues?  Any feedback would be appreciated.
  • 2.  RE: Upgrade 650 Controller from 5.0.2.0 to 5.0.4.115.
    Posted Feb 27, 2014 02:32 PM
    You should be able to upgrade directly.
    Just make sure you do flash backup of your controller before you do.
  • 3.  RE: Upgrade 650 Controller from 5.0.2.0 to 5.0.4.115.
    Posted Feb 27, 2014 05:31 PM
    Yes you can upgrade directly for that scenario. If going to 6.x then you would've needed that 5.0.4.x as an in-between step.
