last person joined: 4 hours ago
Upgrading Issue
  • 1.  Upgrading Issue
    Posted Mar 18, 2015 07:54 PM
    Hey Guys
    I m facing an issue with 620 , When i upgrade it form AOS 6.4.0.3 to 6.4.1 it keeps give me errors such as:
    - upgrade from USB : no file found
    - Upgrade TFTP : cant verify the version
    - Local option is dimmed
    Can any body help me
  • 2.  RE: Upgrading Issue
    Posted Mar 19, 2015 01:03 AM
    Are you sure you are using the correct upgrade file?  Which one are you using?
  • 3.  RE: Upgrading Issue
    Posted Mar 28, 2015 08:02 AM
    I solved the Issue , by Booting with Partion 1 and upgrade Partion 0
