Using ArubaOS 8 APIs to set up a WiFi Network
This thread has been viewed 16 times
  • 1.  Using ArubaOS 8 APIs to set up a WiFi Network
    Posted Aug 10, 2018 09:18 AM
    This post will walk through on how to configure a WiFi Network using APIs. This will be helpful to any Developer or Automation Engineer to get started with APIs available in ArubaOS 8 and do their further exploration. You might find the "Inputs" used in the "POST Body" useful.
    My Setup:
    The following is how the Setup looks, I am going to configure an SSID called “API-Demo” on the cluster using API calls.
    I will be using Postman tool and will also share the equivalent Container and Object which was referred in the Swagger UI.My-Setup.jpg
    The following is my Configuration Node hierarchy.
    I will be creating all the configurations on the Group  “/md/Campus-A”
    Assumption:
    Mobility Master and Managed Devices are UP and running.
    The APs are terminated on the Cluster.
    Swagger UI:
    Swagger UI can be accessed using the following link
    https://<MM-IP-Address>/api/
    Postman
    Get Postman downloaded and installed on your Windows or Mac. Now let’s get started.
    Controller Login:
    First I need to login into the Controller in order to start configuring.Controller Login.jpg
    I will be getting an "UIDARUBA": "0a94f2e6-a967-458d-bcc9-ebea0cf3c15c" which will be used in subsequent API calls.
    Create User VLAN:
    Swagger UI:
    CONTAINERS
     Interfaces
    OBJECT
     POST /object/vlan_id
     Postman:
    Create Dot1x Auth Profile:
    Swagger UI:
    CONTAINERS
         Authentication
    OBJECT
         POST /object/dot1x_auth_profile
    Postman:Create Dot1x Auth Profile.jpg
    Create AAA Profile:
    Swagger UI:
    CONTAINERS
         Authentication
    OBJECT
         POST /object/aaa_prof
    Postman:Create aaa profile.jpg
    Create SSID Profile:
    Swagger UI:
    CONTAINER
     WLAN
    OBJECT
     POST /object/ssid_prof
    Postman:Create SSID Profile.jpg
    Create Virtual AP Profile:
    Swagger UI:
    CONTAINER
     WLAN
    OBJECT
     POST /object/virtual_ap
    Postman:Create Virtual AP Profile.jpg
    Link to AP-Group:
    Swagger UI:
    CONTAINER
     WLAN
    OBJECT
     POST /object/ap_group
    Postman:AP-Group Linking.jpg
    Write Memory:
    Swagger UI:
    CONTAINER
     Controller
    OBJECT
     POST /object/write_memory
    Postman:Write Memory.jpg
    Verification:
    Verifying if "API-Demo" SSID is created:BSS Table.jpg
    EXTRAS - BONUS :)
    1) Getting VLANS:
    How to get the VLAN configured in the Controller 192.168.17.177 (/md/Campus-A/20:4c:03:15:b9:9c)
    Swagger UI:
    CONTAINER
     Interfaces
    OBJECT
     GET /object/vlan_id
    Postman:Get VLAN for MD1.jpg
    2) Show Commands:Get AP Database.jpg
    3) Enable/Disable SSID:
    Swagger UI:
    CONTAINER
     WLAN
    OBJECT
    Postman:
    Disable SSID:Disable SSID.jpg
    Enable SSID:
    Hope you find this useful. Please post your feedback !
    Kapildev Erampu
  • 2.  RE: Using ArubaOS 8 APIs to set up a WiFi Network
    Posted Sep 02, 2019 04:38 AM
    I get the following error when creating the aaa profile:
    Error: Role 'authenticated' is user defined, and can't be applied without Next Generation Policy Enforcement Firewall
    What does that mean and also what is the diffrence between `authenticated` and `guest` roles ?
