VLAN configuration between AP and Controller
  • 1.  VLAN configuration between AP and Controller
    Posted Jun 08, 2017 03:27 PM
    Hi guys,
    I am new in controllers and a little confused about the VLAN configuration between an AP, a controller and across all the network. Here I draw two cases:
    If I want to service clients in both WLANs Employee and Guest. How do every port need to be configured? Let's take VLAN 1 as the native VLAN. For example, I think is
    Case A:
    Eth0: Access in VLAN1
    Eth1: Access in VLAN1
    Gig0/0: Access in VLAN1
    Gig0/1: Trunk with allowed VLANs2-3
    Case B:
    Gig0/1: Trunk with allowed VLANs1-3
    Is this correct?
    Julián
  • 2.  RE: VLAN configuration between AP and Controller
    Posted Jun 08, 2017 03:43 PM
    APs do not need trunks.  They need access ports.  They tunnel all of their traffic back to the controller.  Where the controller connects to the layer 3 switch is where the user trunks need to be configured.
  • 3.  RE: VLAN configuration between AP and Controller
    Posted Jun 08, 2017 03:48 PM
    Hi Colin,
    I understand. But the access ports in what VLAN? For example, what VLAN in the access port in the cases I illustrated?
    Julián
  • 4.  RE: VLAN configuration between AP and Controller
    Posted Jun 08, 2017 03:50 PM
    It does not matter.  The access points just need to be able to reach the controller.
  • 5.  RE: VLAN configuration between AP and Controller
    Posted Jun 08, 2017 03:58 PM
    Then the VLAN doesn't matter, simply the VLAN I choose need to "touch" the AP and the controller, am I right?
    Julián
  • 6.  RE: VLAN configuration between AP and Controller
    Posted Jun 08, 2017 04:02 PM
    The ip address of the AP can be on a different VLAN than the controller.  The ip address just needs to be able to send traffic to the ip address (route) to the controller.
  • 7.  RE: VLAN configuration between AP and Controller
    Posted Jun 09, 2017 10:00 AM
    Ok Colin, many thanks!
    Julián
