Visual RF Plan - Drawing Continuous Walls
  • 1.  Visual RF Plan - Drawing Continuous Walls
    Posted Jun 26, 2015 12:08 PM
    Hi All,
    In Visual RF Plan standalone, is there a way to draw continuous walls without using regions?
    I feel like I'm missing a very simple "shift-click" like solution. Drawing them one wall at a time works only OK as sometimes theres gaps which causes spotting on the diagrams.
    n151
  • 2.  RE: Visual RF Plan - Drawing Continuous Walls
    Posted Jun 30, 2015 10:37 AM
    There is a trick I found for having continuous walls:
    If you draw a planning region, in the bottom right is a checkbox for "Save Region as walls". The region can be built with the click-click-click I think you're looking for.  After you've finished the area, right click and delete the region, which leaves the walls behind.
    I hope this helps!
    - jhenley
  • 3.  RE: Visual RF Plan - Drawing Continuous Walls
    Posted Jun 30, 2015 12:49 PM
    It's not pretty but it works!
    Thanks.
