VisualRF Plan, Ceiling Height & AP Placement
  • 1.  VisualRF Plan, Ceiling Height & AP Placement
    Posted Apr 09, 2014 11:57 PM
    It doesn't look as if setting the distance between floors makes any difference to the Heatmap displayed in VisualRF Plan when placing APs.
    Is there a maximum "distance between floors (ft)" that VisualRF Plan will acknowledge?
    Does setting the "distance between floors (ft)" in the building or setting "Ceiling Height (ft)" when adding a floor plan make any difference in the Heatmap shown once you add APs?
    If anyone has any experience w/ this I'd really like to hear it.
    I'm running 7.6.0 (build: 370)...  Better see if there's an upgrade...
  • 2.  RE: VisualRF Plan, Ceiling Height & AP Placement
    Posted Apr 11, 2014 10:52 AM
    I am unsure what the max value here is but unless this is a warehouse or something with very high ceilings, these values are left as defaults.
