Voice over WLAN (VoW) License Requirements
  • 1.  Voice over WLAN (VoW) License Requirements
    Posted Aug 15, 2014 09:25 AM
    Hope you all are good and prosper.
    Can anyone please confirm whether we need to have any kind of licenses installed in the controller for Voice of WLAN functionality? If yes, is it based on the number of APs or number of end user devices?
    Also, suggest if we can achieve VoW functionality for remote users (via RAP or normal internet connectivity from any devices) as well?
    Thanks.
  • 2.  RE: Voice over WLAN (VoW) License Requirements
    Posted Aug 15, 2014 09:27 AM
    No licenses needed.
    Many customers run VoIP over RAPs.
  • 3.  RE: Voice over WLAN (VoW) License Requirements
    Posted Aug 15, 2014 09:38 AM
    Thanks for such a prompt response cappalli :)
    For VoW to work, are there specific set of requirements in the existing network (or in the controller for that matter) to have in remote site where RAPs would be installed?
  • 4.  RE: Voice over WLAN (VoW) License Requirements
  • 5.  RE: Voice over WLAN (VoW) License Requirements
    Posted Aug 15, 2014 11:39 AM
    thanks for your help :)
