W620 + AP-105 (remote mode). Forbiden external connections.
I have W620 controller and AP-105 Access Point running in remote mode. AP-105 connected with controller through IPsec VPN.  Also AP-105 runnung in bridge mode. I can ping wireless clients from the outside. But another external connections are forbidden. How to allow other external traffic?
Re: W620 + AP-105 (remote mode). Forbiden external connections.
What role are the client being assigned? you can see the role assigned in the user table.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
current user roles
You might have to modify the uplink ACL  https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-970
Not sure if you can do that without the PEF license, though.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
