Contributor I
WMS database not updated on Master controller
I had issues with centralized licensing and while resolving the issues I cleared the gap-db for all my local controllers and now all my AP's are not showing up on the Master.  All the Local controllers are synced to the Master.
Has anyone had seen anything like this or know how to resolve database issues between Master and Local controllers.
I have a case open and was curious if anyone has seen this issue before.
Will a database initialization sync up the database between all the controllers?
Re: WMS database not updated on Master controller
I would wait for TAC on that one.  Between what you did and what you are seeing, it could be anything.
