What are some common issues stopping AP from sucessfully provisioned?
  • 1.  What are some common issues stopping AP from sucessfully provisioned?
    Posted Sep 25, 2017 08:34 PM
    1. Make sure that contoller firmware supports the required AP (e.g., AP-303H requires 6.5.2.0 or above)
    2. Make sure that there is license capacity available especially LIC-AP.  This can be found under Configuration - Controller - License in GUI or show license client-table.
    3. Make sure that CPsec setting is correct. http://community.arubanetworks.com/t5/Wireless-Access/AP-boots-up-but-not-visible-under-show-ap-database/td-p/308292
    4. Make sure that AP is provisioned correctly
    http://community.arubanetworks.com/t5/Wireless-Access/AP-was-visible-under-default-group-but-not-anymore-after-Appy/td-p/308295
    Usually we will be able to provision the AP once the above conditions are fixed.
