When CPsec is enabled, what tunnel protocol is used between AP and controller?
  • 1.  When CPsec is enabled, what tunnel protocol is used between AP and controller?
    Posted Jun 14, 2016 04:45 AM
    Hi, please advise what tunnel protocol is used between AP and controller when CPsec is enabled. thanks in advance.
  • 2.  RE: When CPsec is enabled, what tunnel protocol is used between AP and controller?
    Posted Jun 14, 2016 04:48 AM
    IPSec is used for the management/control plane tunnel.
  • 3.  RE: When CPsec is enabled, what tunnel protocol is used between AP and controller?
    Posted Jun 14, 2016 05:38 AM
    Thanks for reply.
    But in monitoring , IPsec is disable under AP , please advise.
  • 4.  RE: When CPsec is enabled, what tunnel protocol is used between AP and controller?
    Posted Jun 14, 2016 06:51 AM
    PeterLee,
    Ipsec is used for tunneling user traffic only for an access point that is configured as a Remote AP.  Turning on CPSEC only puts the control plane, which is not user traffic, into an ipsec tunnel.  You will only see the IPSEC number on the monitoring page for RAPs, because the user traffic is in an ipsec tunnel.  You will not see the IPSEC number because CPSEC is on, because CPSEC does not turn on ipsec tunneling for user traffic.
    I hope this helps.
  • 5.  RE: When CPsec is enabled, what tunnel protocol is used between AP and controller?
    Posted Jul 24, 2018 01:31 AM
    which tunnel protocol used in network when CP sec enable?  below select option
    A IPsec
    B GRE
    C HTTPS
    D PPTP
