Contributor I
Which Aruba 3600 controller (master-slave) needs to have CA cert installed on it?
Hello -
I have been trying to get eap-tls working with our Cisco ACS server with no luck.  I am going to try and get this to work with eap-tls terminating on the controller.  We currently have one master controller and two slave controllers.  The APs which will be using eap-tls to authenticate its clients with are provisioned to one of the slave controllers and not the master.
I have found the EAP-TLS Termination word document but it did not look like it was setup with a master-slave controller configuration.
Do I need to install a CA cert on both the master and slave, the master, or just the slave?
Thanks in advance for the help.
Re: Which Aruba 3600 controller (master-slave) needs to have CA cert installed on it?
Both.
Contributor I
Thanks cjoseph!
