Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
This thread has been viewed 39 times
  • 1.  Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Dec 04, 2011 09:47 PM
    Why doesn't my Aruba Access Point Find My Controller? - Part 1.  Covers the importance of the DNS a-record of "aruba-master" and the DHCP domain name in Aruba Controller Discovery.
  • 2.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Dec 06, 2011 03:10 PM
    Just a point of clarification, Colin.  AP master discovery uses the following methods, in order, to find its master.
    1.  DHCP option
    2.  ADP
    3.  DNS
    If you don't use the DHCP option but do use ADP, DNS doesn't even come in to play, does it?
  • 3.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Dec 06, 2011 04:31 PM
    If all of those methods were mentioned, there wouldn't be a part 2.
  • 4.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    MVP
    Posted Dec 07, 2011 11:58 AM
    You forgot #1 Mike :smileytongue:
    AP boot order
    1)    “master” parameter set (manualy) on the AP
    2)    dhcp option 43
    3)    ADP multicast & broadcast
    4)    DNS aruba-master
  • 5.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Nov 08, 2012 06:38 AM
    I'm wondering whether there is a way to validate remotely which method was used?
    Also if the "master" parameter is manually set on the AP, is there a way to remotely remove this?
  • 6.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Nov 08, 2012 07:09 AM
    Unfortunately, there is no way to remotely validate or remove those parameters.  It must either connect to the controller, where you can provision it there, OR you can change those variables physically via the console.
  • 7.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Nov 12, 2012 08:45 AM
    Having worked with these parameters in a bit in the field the last few days in order to get some APs working which had DNS difficulties I noticed something interesting. When I wanted to re-provision an AP that was setup with a fixed Master IP locally I saw that within the Master Discovery part of provision menu it now had the 'Master controller IP address/DNS name' filled in rather than the "Host controller Name".
    I'm wonder if these settings do not reflect whether it will:
    1.) Look at the Master controller IP - which is the one that is manually configured IP on the console
    2.) Find the controller through DNS looking for the 'aruba-master' if this is deleted and converted back to 'Host controller Name' filled in.
    Unfortunately I don't have a lab setup at the moment where I can test this but it would sound logical to me.
    Anyone who can confirm or would like to test this?
    I'm sure this would be interesting for some of you as well in case you run in the same situation in the field :)
  • 8.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Nov 23, 2012 11:47 PM
    Dear ,
    i can place aruba controller in different network ? , AP can find controller eventhough both are in different network ?
  • 9.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Nov 23, 2012 11:51 PM
    Using the DNS discovery method.. yes...
  • 10.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted May 23, 2016 08:29 AM
    Hello
    Below are my Aruba AP205 logs
    Configuration is done under Vendor specific info, but cant connect to the controller.
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Uncompressing... done
    [    0.000000]
    [    0.000000] Aruba Networks
    [    0.000000] ArubaOS Version 6.4.3.6 (build 52927 / label #52927)
    [    0.000000] Built by p4build@lesbos on 2015-12-11 at 15:43:45 PST (gcc version 4.7.2)
    [    0.000000]
    [    0.000000] Flash variant: variant0
    [    0.000000] MPCORE found at 19020000, SCTLR 0x10c53c7f ACTLR 0x00000040 CPSR 0x600001d3 SPSR 0x60000013 PRRR 0x000a81a8 NMRR 0x40e040e0
    [    0.000000] Memory: 128MB = 128MB total
    [    0.000000] Memory: 120676k/120676k available, 10396k reserved, 0K highmem
    [    0.052000] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
    [    3.468000] PMU: registered new PMU device of type 0
    [    3.976000] pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
    [    3.978000] pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
    [    3.980000] pci 0001:01:00.0: BAR 0: set to [mem 0x08000000-0x08007fff 64bit] (PCI address [0x8000000-0x8007fff]
    [    4.484000] pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
    [    4.486000] pci 0002:02:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
    [    4.488000] pci 0002:02:00.0: BAR 0: set to [mem 0x40000000-0x40007fff 64bit] (PCI address [0x40000000-0x40007fff]
    [    4.832000] i2c-springbank: using remapped base c9e54060
    [    4.836000] mpcore_wdt mpcore_wdt: enabling watchdog.
    [    4.840000] qspi_iproc qspi_iproc.1: 1-lane output, 3-byte address
    [    4.842000] m25p80 spi1.0: mx25l25635e (32768 Kbytes)
    [    4.846000] Creating 1 MTD partitions on "spi1.0":
    [    4.848000] 0x000000000000-0x000002000000 : "qspi"
    [    4.860000]
    [    4.860000] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [    4.864000] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [    4.926000] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [    4.930000] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [    4.932000]
    AP-type has_ble_support: .
    Domain Name: arubanetworks.com
    No panic info available
    [   13.746000] AP xml model 81, num_radios 2 (jiffies 6873)
    [   13.748000] init_asap_mod: installation:0
    [   13.750000] radio 0: band 1 ant 0 max_ssid 16
    [   13.752000] radio 1: band 0 ant 0 max_ssid 16
    USB is not supported on this model
    Starting watchdog process...
    Getting an IP address...
    [   14.890000] ADDRCONF(NETDEV_UP): bond0: link is not ready
    [   19.900000] bond0: link up (1000FD)
    [   19.902000] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    10.73.8.84 255.255.255.0 10.73.8.1
    Running ADP...cat: /tmp/master: No such file or directory
    Done. Master is
    killall: nanny: no process killed
    killall: sapd: no process killed
    Sending SIGKILL to all processes.
    Please stand by while rebooting the system.
    [  120.132000] Restarting system.
    Please anyone with idea please
  • 11.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted May 24, 2014 04:55 PM
    yes
  • 12.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted May 23, 2016 08:30 AM
    Please assists, confused here.
  • 13.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted May 24, 2016 06:13 AM
    might be wiser to start a new topic. did you confirm the usual suspects, i.e. is the controller on the same L2 network (as DHCP seems to work). did you try reseting the AP?
  • 14.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted May 24, 2016 06:16 AM
    Yes reset was done. AP seems to work fine from other site which are managed
    by same controller but not at my site.
  • 15.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted May 24, 2016 06:29 AM
    what is the difference between the sites? what method do you use for controller discovery?
  • 16.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted May 24, 2016 06:44 AM
    Globally we are using DHCP,
    have configured vendor specific.
  • 17.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted May 24, 2016 07:45 AM
    Does it work anywhere?  Please show us your DHCP server configuration.
  • 18.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Feb 16, 2017 09:53 AM
    I have the same issue...
    My new ap 205 can't be viewer on my 3200 controller.
    Checking image @ 0x1e100000
    Copying image from 0x1e100000
    Signer Cert OK
    Policy Cert OK
    [ 0.000000]
    [ 0.000000] ArubaOS Version 6.4.2.6-4.1.1.13 (build 54918 / label #54918)
    [ 0.000000] Built by p4build@rhodes on 2016-05-06 at 05:00:19 PDT (gcc version 4.7.2)
    [ 0.000000]
    [ 0.000000] MPCORE found at 19020000, SCTLR 0x10c53c7f ACTLR 0x00000040 CPSR 0x600001d3 SPSR 0xa7006200 PRRR 0x000a81a8 NMRR 0x40e040e0
    [ 0.000000] Memory: 117664k/117664k available, 13408k reserved, 0K highmem
    [ 5.358000] PMU: registered new PMU device of type 0
    [ 5.864000] pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
    [ 5.866000] pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
    [ 5.868000] pci 0001:01:00.0: BAR 0: set to [mem 0x08000000-0x08007fff 64bit] (PCI address [0x8000000-0x8007fff]
    [ 6.372000] pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
    [ 6.374000] pci 0002:02:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
    [ 6.376000] pci 0002:02:00.0: BAR 0: set to [mem 0x40000000-0x40007fff 64bit] (PCI address [0x40000000-0x40007fff]
    [ 6.722000] i2c-springbank: using remapped base c8914060
    [ 6.724000] mpcore_wdt mpcore_wdt: enabling watchdog.
    [ 6.728000] qspi_iproc qspi_iproc.1: 1-lane output, 3-byte address
    [ 6.730000] m25p80 spi1.0: mx25l25635e (32768 Kbytes)
    [ 6.732000] Creating 1 MTD partitions on "spi1.0":
    [ 6.734000] 0x000000000000-0x000002000000 : "qspi"
    [ 6.736000]
    [ 6.736000] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [ 6.740000] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [ 6.754000] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [ 6.758000] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [ 6.760000]
    Domain Name: instant.arubanetworks.com
    apfcutil: sector CACHE: Cache uninitialized
    apfcutil: sector RAP: Cache uninitialized
    apfcutil: sector FAT: Cache uninitialized
    apfcutil: sector SCRATCH: Cache uninitialized
    Check backup ENV.
    apfcutil: sector MESH Prov: Cache uninitialized
    Cfg len is 0
    Configuration file is empty, turning on default services...
    extended ssid activate due to no AP config ...
    [ 14.534000] ADDRCONF(NETDEV_UP): bond0: link is not ready
    [ 16.538000] bond0: link up (100FD)
    [ 16.540000] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    Mesh is DISABLED on this device.
    Disabling wpa_supplicant for this paltform
    [ 17.606000] AP xml model 81, num_radios 2 (jiffies 8803)
    [ 17.608000] init_asap_mod: installation:0
    [ 17.610000] radio 0: band 1 ant 0 max_ssid 16
    [ 17.612000] radio 1: band 0 ant 0 max_ssid 16
    [ 17.614000] election init: rand=16 HZ=500
    [ 17.616000] IAP client match init
    notify asap_mod 3g no present...
    Dec 31 16:00:19 udhcpc[1361]: udhcpc (v0.9.9-pre) started
    Dec 31 16:00:19 udhcpc[1361]: send_discover: pkt num 0, secs 0
    Dec 31 16:00:19 udhcpc[1361]: Sending discover...
    Dec 31 16:00:19 udhcpc[1361]: send_selecting: pkt num 0, secs 0
    Dec 31 16:00:19 udhcpc[1361]: Sending select for 172.16.6.57...
    Dec 31 16:00:19 udhcpc[1361]: Lease of 172.16.6.57 obtained, lease time 691200
    Dec 31 16:00:19 udhcpc[1361]: DHCP OPT 43 deleted airwave config
    172.16.6.57 255.255.0.0 172.16.0.1
    Compressing all files in the /etc/httpd directory...
    [ 22.624000] ip_time_handler: Got ip and packets on bond0 Started master election 89-0, rand 24
    Done.
    Starting Webserver
    bind: Transport endpoint is not connected
    Launching NTP Client on pool.ntp.org
    [ 24.622000] wifi0: AP type AP-205, radio 0, max_bssids 16
    [ 24.666000] wifi1: AP type AP-205, radio 1, max_bssids 16
    shutting down watchdog process (nanny will restart it)...
    Completed SW FIPS KAT test
    <<<<< Welcome to the Access Point >>>>>
    User: [ 43.856000] process `snmpd_sap' is using obsolete setsockopt SO_BSDCOMPAT
    [ 46.656000] i am master now
    [ 46.658000] (00:00:48) !!! Init ---> Master
    [ 46.660000] asap_send_elected_master: sent successfully.
  • 19.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Feb 16, 2017 09:55 AM
    That is an instant AP.
     It must be converted to a campus AP before it can be used with a controller.  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-do-I-convert-an-Aruba-Instant-AP-to-a-campus-AP/ta-p/178988
  • 20.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Oct 06, 2014 05:25 PM
    Could I please have access to view this video. Thanks!
  • 21.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Oct 12, 2014 05:52 AM
    good point, ozwifi / cjospeh the video now says it is private.
  • 22.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Oct 12, 2014 06:34 PM
    Fixed.
  • 23.  RE: Why Doesn't My Aruba Access Point Find My Controller (Part 1) (7:05)
    Posted Oct 13, 2014 05:07 AM
    perfect, thanks.
