Is there any way to filter which ports are used for detection of rouge APs/upstream APs on wired ports to exclude trunked ports?
In some segments of our network where we have some flatness, we have multiple switches with trunked ports on the same VLAN. So, when the AP rouge wired detection occurs, it is often found on a) the legimiate port and b) all of the trunked ports on the same segment. Depending on what saw it last(?), the reported upstream device is likely to be wrong.
We're an Enterasys wired shop; switches are added as "Router/Switch" types.
Any ideas?
