last person joined: 10 hours ago
Wireless Bridge Detection help
  • 1.  Wireless Bridge Detection help
    Posted Jan 05, 2013 11:46 PM
    we are seeing much of wireless bridge detection in our environment those are detected by IDS my question is how can we track down that wireless bridge location  just to see if it exixt inside our network. may be someone is turning is wireless hotspot on their with softwares like connectify etc and bridges are geting detected.
    Thanks for help in advance.
  • 2.  RE: Wireless Bridge Detection help
    Posted Jan 06, 2013 07:08 AM
    When it says that a wireless bridge is detected, it also says which access point hears it.  Start looking near that access point.
  • 3.  RE: Wireless Bridge Detection help
    Posted Jan 06, 2013 10:44 AM
    right but from controller point of view how can we check , reason behind is AP's are at remote location any specific command with help of which we can check .
    thanks for help
  • 4.  RE: Wireless Bridge Detection help
    Posted Jan 07, 2013 04:16 AM
    Can we do it with the help of map. I mean if you upload RF plan in the controller???
  • 5.  RE: Wireless Bridge Detection help
    Posted Jan 07, 2013 05:34 AM
    You need at least 3 access points on a map, unfortunately, to triangulate a device...
  • 6.  RE: Wireless Bridge Detection help
    Posted Jan 21, 2013 10:12 AM
    in my experience, on a remote site, you either dispatch a technician to investigate or have someone onsite look for you around the AP that had discovered it.
    On the controller you can run 'show wms ap list', 'show log security'. Amongst other commands to see what is going on.
    If you have Airwave, you can look at the RAPIDS IDS Events list and find the particular Wireless Bridge Event to investigate further.
    You can then run more detailed commands on the user's MAC, etc..
    But if you can get hands-on on site, it would be best imo
  • 7.  RE: Wireless Bridge Detection help
    Posted Nov 11, 2014 02:42 AM
    Issue is mac address is always changing  and when trying to search mac dont see it on airwave,
