We currently have a 10 gig port-channel setup on our 7240 controllers , we setup a port mirroring from one of the indiviual trunks of the port-channel (Aruba doesn't support port mirroring on a port-channel) and performed a packet caputure using Wireshark to stop capturing after 1 minute when completed the capture file was 1.4 Gigs.
At the same time we performed a port mirroring on the uplink switch ( Cisco doesn't allow you mirror an interface/port that is one of the members of a port-channel) which is reverse to what Aruba allows , the only option left was to do the port mirroring from the port-channel . Ran the packet capture using Wireshark to stop after 1 minute and when completed the capture file was 500 Megs.
My question is : When the Aruba controller does the conversion (Integration Service) from 802.11 removes the 802.11 header/trailer and encase it in a 802.3 frame , will you see a reduction in the amount of traffic on the other end once the frames are converted to 802.3 (Cisco uplink/ethernet) compare to the traffic seen before it gets converted over.
#7240
