Occasional Contributor I
Xbox 360s not working with AP 215s but do connect to AP 105s?
We recently upgraded all of our dorm APs from 105s to 215s.  No Xbox 360s are working with the AP 215s.  No configuration changes have been made during the upgrade.  I have a ticket open with TAC, but wanted to check if anyone else has experienced this issue?
Re: Xbox 360s not working with AP 215s but do connect to AP 105s?
What version of ArubaOS?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
The issue has been ocurring with 6.4.3.7 and is still happening with 6.4.4.9.
Are you using encryption or the SSID is open?
No encryption, it is open
Do you have lower rates removed on that SSID?
Yes, here are the rates:
