Contributor II
airprint capability without disabling drop multicast & broadcast
We have noticed performance issues when disabling drop multicast & broadcast from VAP profile, Is there a way to have airprint & airplay capablitlty with drop multicast & broadcast check box selected but just allow airprint & airplay multicast.
Mathew
Re: airprint capability without disabling drop multicast & broadcast
mgeorge,
The soon-to-be-released Airgroup feature will support that:  http://www.arubanetworks.com/pdf/technology/TB_AirGroupWLANServices.pdf
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
cjoseph,
Can you be anymore specific on soon-to-be-released? By the end of June, end of  July, sometime in August?
Ben
I do not know, but there certainly will be an annnouncement here..
