i've read the specs and it says that arrestors also need to be grounded. do you guys carry a grounding kit?
I will be installing an AP 224, arrestors, pigtail cables, and ANT 92. Will this work? PN: ANT-CBL-1 (Aruba Outdoor RF Cable 1M Long N/M to N/M Flexible Jumper). Correct me if i am wrong but this wouldn't work because pigtail cable has male typed connectors on each end.
for example, AP 224 (female) - Arrestors (male - female) - cable ( male - male) - Antenna ( Male).
do you have male - female pigtail cables?
Thank you
