ap325 ethernet
The ap 325 specs report:
Two 10/100/1000BASE-T Ethernet network interfaces (RJ-45)
  • Auto-sensing link speed and MDI/MDX
  • Load balancing support to achieve platform throughput greater than 1 Gbps
Can anyone point me to docs on how the wired load balancing works and/or is set up?  Has anyone had problems with this?  Do the links need to go to the same switch and be lagged?  What happens when one of them goes down?
Re: ap325 ethernet
They behave the same as the 220 series. If you have stacked switches, the recommendation is to split the links across the stack using LACP.
If the switch providing initial power goes down, the AP will reboot and come up on the second switch.
Sent from Nine<>
Tim Cappalli | Aruba Security
Re: ap325 ethernet
awesome - can you point me to the latest docs which gives the details please
Re: ap325 ethernet
