Hi
Can anyone advise what means "ath_key_reset: MAC is busy. Reseting radio" log below?
Does it affect wireless connection or authenticaion?
Regards
Simon
show ap debug driver-log ap-name "AP001215_AOseizo"
Driver Log
Current Log Level 3 Log Counter 53 Timestamp 5293613.485524
1 0.0 aruba100: Scheduling VAP CONFIG update
2 0.312 aruba100: Encryption Mode Set to 4
3 0.362 aruba100: WPS Mode Set to 0
4 0.396 aruba100: 40mhz enable to 1
5 0.429 aruba100: 40mhz GI to 1
6 0.460 aruba100: STBC TX streams to 1
7 0.492 aruba100: STBC RX streams to 1
8 0.524 aruba100: Beacon rate to 1000
9 0.560 aruba100: A-MPDU: Enabled, Tx Max 65535 Rx Max 3 Min Spacing 6
10 0.605 aruba100: Basic Rate Set to 3
11 0.637 aruba100: Supported Rate Set to fff
12 0.674 aruba100: DTIM Period Set to 1
13 0.674 aruba100: ESSID Set to JPN-WL-NW
14 0.674 aruba100: Max Retries Set to 8
15 0.674 aruba100: RTS Threshold Set to 2333
16 0.674 aruba100: Ageout Set to 1000
17 0.674 aruba100: WMM DISABLED
18 0.674 aruba100: VAP CONFIG DONE
19 0.16118 wifi1: Country Code Set to JP
20 0.26874 wifi1: EIRP (Config: 0.-5dBm, Set: 20.0dBm, AP Max: 20.0dBm, Reg Max: 20dBm), Conducted Power Set: 20.0dBm, Gain: 0.0dBm
21 0.26943 wifi1: Channel Set to 11 (mesh-mode: 0, state: 0)
22 0.26984 wifi1: Internal Antenna Gain Set to 2.5 dB for 2.4 GHz
23 0.27022 wifi1: Internal Antenna Selected
24 0.27182 wifi1: EIRP (Config: 24.0dBm, Set: 20.0dBm, AP Max: 22.5dBm, Reg Max: 20dBm), Conducted Power Set: 17.5dBm, Gain: 2.5dBm
25 0.27242 wifi1: disabling 40Mhz
26 0.27293 wifi1: RADIO CONFIG DONE
27 0.33602 wifi1: Scheduling RADIO CONFIG update
28 0.37132 wifi1: Country Code Set to JP
29 0.58316 wifi1: EIRP (Config: 24.0dBm, Set: 7.5dBm, AP Max: 22.5dBm, Reg Max: 20dBm), Conducted Power Set: 5.0dBm, Gain: 2.5dBm
30 0.58387 wifi1: Channel Set to 11 (mesh-mode: 0, state: 5)
31 0.58428 wifi1: Internal Antenna Gain Set to 2.5 dB for 2.4 GHz
32 0.58468 wifi1: Internal Antenna Selected
33 0.58505 wifi1: Antenna Mode Selected: AUTO
34 0.58541 wifi1: disabling 40Mhz
35 0.58588 wifi1: RADIO CONFIG DONE
36 196155.254072 ath_key_reset: MAC is busy. Reseting radio
37 306926.329098 ath_key_reset: MAC is busy. Reseting radio
38 451663.747498 ath_key_reset: MAC is busy. Reseting radio
39 802219.303476 ath_key_reset: MAC is busy. Reseting radio
40 2117485.224168 ath_key_reset: MAC is busy. Reseting radio
41 3131989.76924 ath_key_reset: MAC is busy. Reseting radio
42 3164581.673496 ath_key_reset: MAC is busy. Reseting radio
43 3402043.436891 ath_key_reset: MAC is busy. Reseting radio
44 3904357.234959 ath_key_reset: MAC is busy. Reseting radio
45 3907764.155897 ath_key_reset: MAC is busy. Reseting radio
46 4536776.196264 ath_key_reset: MAC is busy. Reseting radio
47 4537379.961135 ath_key_reset: MAC is busy. Reseting radio
48 4537824.988923 ath_key_reset: MAC is busy. Reseting radio
49 4538634.378188 ath_key_reset: MAC is busy. Reseting radio
50 4967207.22191 ath_key_reset: MAC is busy. Reseting radio
51 4981542.474200 ath_key_reset: MAC is busy. Reseting radio
52 5117068.39064 ath_key_reset: MAC is busy. Reseting radio
