Frequent Contributor II
can I limit numbwe of users per access point?
I need ro limit number od users per access point for guest
Aruba
Re: can I limit numbwe of users per access point?
You can limit the number of concurrent connected users per Virtual AP (which is applied per AP) through the Max Associations configuration.
AMFX | ACCX | ACDX | ACMX
