Frequent Contributor II
changing rap 3 remote IP
Hi all, any easy way to point some RAP3's at a new Public IP ?  can this be pushed out from controller ?
ACMA/ACMP
Re: changing rap 3 remote IP
You can use a provisioning profile to change the master IP that is saved in
flash.
Tim Cappalli | Aruba Security
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/AP-Configuration-Profiles-versus-AP-Provisioning-Profile/m-p/21358/highlight/true#M7460
thanks chaps excellent as always
ACMA/ACMP
