Frequent Contributor I
clarification on Master Redundancy and Fast Failover
Hi.
Currently I have 2 controllers set for Master Redundancy (active/standby) and Fast Failover (both set as dual) at the same time. In AP profile LMS IP has IP address of active controller and backup LMS IP has IP address of standby controller.
The problem is when I break communication between APs and both controllers for a moment (controllers notice that APs are down) and then restore communication, APs will not reconnect to any controller. I have to reboot APs.
Similar issue is when active controller is down and standby becomes new active then when APs are booted, they will not connect to new active controller.
Is it normal behavior in this setup?
Also can I move some APs (make them active) on standby controller? I think the answer is no but I want to make sure.
Re: clarification on Master Redundancy and Fast Failover
If you are not using locals and all of your APs are terminating on masters, you should not use these two features together.
Tim Cappalli | Aruba Security
Couple of weeks ago I upgraded controllers to 6.4 to have this option supported and it works well except these issues.
I haven't seen any document stating it's not recommended. Can you provide any details? What setup would you recommend?
You can find the below note @ http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/VRRP/HighAvFastFailover.htm
High Availability:Fast Failover provides redundancy for APs, but not for controllers. Deployments that require master controller redundancy should continue to use an existing VRRP redundancy solution.
Rajaguru Vincent
Rajaguru Vincent
CWNA | CWSP | CWAP | CWDP | ACMP
I know that note but for me it means that Fast Failover can be used for AP redundancy and VRRP can be used for controller redundancy. For me these are two seperate solutions but one doesn't exclude the second one.
Anyway, what solution would you recommend?
The only issue I see is if APs build a second stand by tunnel but because the controller is part of the stand by master redundancy it won't build it since the standby master by default can't build a any tunnels with APs until
It becomes the primary
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I think the tunnels are established because 'show ap standby' on standby controller displays all APs and during failover APs become active very quickly (without it I think it would take much longer).
I thought you mentioned that APs were not able to reconnect when standby became active
Thank you
Victor Fabian
Remove backup lms IP from AP system profile. Just have LMS IP pointed to Master controller's physical IP address.
Make sure the ip-addresses you are using in HA config are controller/switch IPs and not just any other interface IPs.
Here is my config for Master-Standby Master HA setup:
  • Master (10.10.1.1)
vlan 10
interface vlan 10
  ip address 10.10.1.1 255.255.255.0
controller-ip vlan 10
vrrp 10
  ip address 10.10.1.3
  vlan 10
  no shutdown
  priority 110
master-redundancy
  master-vrrp 10
  peer-ip-address 10.10.1.2 ipsec <key>
Ha group-profile Building-A
  controller 10.10.1.1 role dual
  controller 10.10.1.2 role dual
  state-sync
  pre-shared-key <key>
Ha group-membership Building-A
ap system-profile Building-A
lms-ip 10.10.1.1
  • Standby Master (10.10.1.2)
vlan 10
interface vlan 10
  Ip address 10.10.1.2 255.255.255.0
vrrp 10
  vlan 10
  no shutdown
  priority 110
master-redundancy
  master-vrrp 10
  peer-ip-address 10.10.1.1 ipsec <key>
Thanks. I'll try that configuration.
