clear gap-db, rap access point housekeeping
This thread has been viewed 31 times
  • 1.  clear gap-db, rap access point housekeeping
    Posted Apr 09, 2018 02:00 PM
    I found old post about clearing old AP from controller but for some reason I can't add  RAP AP that was duplicate before. I was trying  individual AP, all "clear gap-db lms lms-ip x.x.x.x, AP is not longer visible but I still get error that it exists
    whitelist-db rap add mac-address "9c:1c:12:c1:7b:74" ap-group "mygroup" ap-name "AP-5-chicken"
    RAP with same MAC address or RAP/Userwith same remote IP already exists
    show ap database long | include 9c:1c:12:c1:7b:74
    nothing
    Even reboot of contorller does not help, version 6.5.4.5
  • 2.  RE: clear gap-db, rap access point housekeeping
    MVP EXPERT
    Posted Apr 09, 2018 02:27 PM
    Hey, have you confirmed that the MAC isn't in the Internal DB?
    #show local-userdb-ap
    #show local-userdb
  • 3.  RE: clear gap-db, rap access point housekeeping
    Posted Apr 09, 2018 02:36 PM
    show whitelist-db rap mac-address x:x:x:x:x:x  does show it
    but GUI
    Wireless > AP Installation > Whitelist  does not
    What is interensting i had 2 APs like that and one of them has just showed up as active but it is not in the whitlist GUI and I cant add it there
  • 4.  RE: clear gap-db, rap access point housekeeping
    MVP EXPERT
    Posted Apr 09, 2018 02:41 PM
    That's odd, is it a standalone controller?
  • 5.  RE: clear gap-db, rap access point housekeeping
    Posted Apr 09, 2018 02:47 PM
    master - local  - all commands done on master
  • 6.  RE: clear gap-db, rap access point housekeeping
    Posted Apr 10, 2018 09:00 AM
    So here is what I found.  In the  GUI remote ap whitelist had next page of APs which I did not see, I found this by using serach field, my bad. But this still does not explain why clear gap-db did not removed it using name or mac address
  • 7.  RE: clear gap-db, rap access point housekeeping
    Posted Apr 10, 2018 09:07 AM
    mke,
    Honestly the GAP db does not have anything to do with the AP or RAP whitelist.  It is only a record that an AP physically associated with the controller.  You can run the clear gap-db command on an AP that is currently up and it will still continue to function and the entry will be put back into the gap-db immediately.
    The purpose of clearing the gap-db is mostly cosmetic so that you do not have to see an AP listed as "Down" that no longer will be on your system.  Clearing the gap-db does not have a functional purpose and it does not disable an access point.
  • 8.  RE: clear gap-db, rap access point housekeeping
    Posted Apr 10, 2018 09:09 AM
    What is then CLI command to remove RAP AP from the whitelist?
  • 9.  RE: clear gap-db, rap access point housekeeping
