controller not saving
Hi
I have aruba 3400 controller. suddenly it is not saving anything, for example i am trying to provision a AP to a group but when i change it and apply it is not working . i have logged in to the console of the ap and change the group. please help
Re: controller not saving
What version AOS are you running ? Is this only happening with one AP?
Have you tried using another browser ?
You could also try provisioning through the controller CLI:
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/provision-ap-ip-address-via-the-controller-command-line/td-p/151168
Thank you
Victor Fabian
Lead Mobility Architect
tried in another browser still the same and it is for all AP. And i am not able to add wlan. i have to configure it through cli. the wlan wizard is not working. i
Model:Aruba3400-US
Version:6.1.3.4
Check the logs and see what might be failing
show log system 50
Thank you
Victor Fabian
Trusted Contributor I
do you also provision your APs via a wizard? because the wizards have been known to act strange. i would try to clear the cache and try again and if it keep failing with other browsers / browser versions.
Frequent Contributor I
browser issue most likely.. faced that several.times... try with IE with aruba it is the best browser to use.
