Perfect, thanks for clarify.
I tried to create a picture of your topology:
It looks like the IP Range for the magic VLAN is overlapping (magic VLAN is used for guest access, descripted in short).
To solve that, try to change the default DHCP Scope to a IP range which you don't need:
