dhcp issues
I've created initial VLAN and 1 ssid (Corp). Then I've created a dhcp scope for that VLAN.
Basically my wireless clients are still getting a dhcp address from our domain controller and not the allocated range on the Aruba wlc
What am I missing ?
Many thanks
Re: dhcp issues
did you do also on the controller,
service dhcp
ACCP, ACCX #817, ACMP, ACMX #294
Re: dhcp issues
thanks, but still no joy
Any ideas
Aruba
Re: dhcp issues
If there are multiple DHCP servers for a network available (in your case the controller and Windows), the first one to respond is where clients will get an IP address from.
First confirm DHCP is setup properly on the controller:
show ip dhcp database
show ip dhcp statistics
show ip interface brief (the controller needs an IP on the VLAN)
Second, if you cannot turn off the scope no the Windows server, you can configure a DHCP helper for the VLAN in question to try and direct the request to where you want.
interface vlan XX
ip helper-address x.x.x.x (IP of controller)
AMFX | ACCX | ACDX | ACMX
Re: dhcp issues
Thanks but still picking up from the domain controller
see attached
many thanks
Re: dhcp issues
Type "show user-table verbose" and see what VLAN# the user is ending up in.  It would be in parentheses in the last column.
Re: dhcp issues
it's ending up in VLAN 1 which is correct
thanks
Re: dhcp issues
The mask in your vlan 1 doesn't match the mask in your scope.
Re: dhcp issues
Ah yes thanks
So we can't issue a separate DHCP pool on the default vlan ?
Re: dhcp issues
The network on the scope needs to match that of your vlan interface, otherwise it won't respond.
If you want to keep using the Windows server for other devices, you should put exclusions in place on both to ensure there is no overlap and ip conflicts.
