fast fail-over inquiry?
  • 1.  fast fail-over inquiry?
    Posted Sep 28, 2016 09:56 AM
    If I have 4 Controllers
    2x Master-active and Standby
    2x locals with (AP fastfailover configure) Active active
    and I have terminated 100 AP on local controller 1 and 100 AP on local controller 2nd I have 500 clinet connected on each controller and as I knew that client state state will be sync ,so thats mean I will see 1000 clinet on each controller? inside the dashboard?
  • 2.  RE: fast fail-over inquiry?
    Posted Sep 28, 2016 10:40 AM
    You will not see clients on the second (standby) controller.  Client state sync refers to synchronizing the client 802.1x key on the second controller so that it does not have to do a 4-way handshake upon failover to the second controller.
