firmware upgrade
  • 1.  firmware upgrade
    Posted Jan 24, 2014 01:18 PM
    I was told that after a certain version of firmware a 620 would not be able to be upgraded due to the size of the firmware. I would like to upgrade to 6.2.1.5 .. do you know if this version will install on a 620?
    thx,
  • 2.  RE: firmware upgrade
    Posted Jan 24, 2014 01:28 PM
    You should be able to. Before you upgrade, run the follwing two commands:
    tar crash
    tar logs tech-support
    Then run to clear out the logs and free up some space.
    tar clean crash
    tar clean logs
     Then run:
    show memory
     You need at least 40 MB free to upgrade using the CLI, or 60 MB to upgrade via the web UI.
  • 3.  RE: firmware upgrade
    Posted Jan 24, 2014 01:38 PM
    thx,, will do ...
