help
  • 1.  help
    Posted Mar 12, 2014 04:44 PM
    I  am trying to delete my IP DHCP excluded -address and I kept getting error message. I use the no ip dhcp excluded-address follow by the ip range. That did not work. Can someone help me as I am a newbie?
  • 2.  RE: help
    Posted Mar 12, 2014 04:51 PM
    What is the error message?
  • 3.  RE: help
    Posted Mar 14, 2014 06:23 AM
    Did you delete the dhcp scope first? If I remember correctly I at some time did that and then was unable to delete the excluded address. Create the dhcp scope again, then delete the excluded range, then delete the scope again.
    Worth a shot ;)
  • 4.  RE: help
    Posted Mar 16, 2014 11:46 AM
    try via the CLI if the GUI acts up is usually my way to handle issues.
