how to configure mesh in iap 207
  • 1.  how to configure mesh in iap 207
    Posted Aug 09, 2017 09:36 AM
  • 2.  RE: how to configure mesh in iap 207
    MVP
    Posted Aug 12, 2017 12:31 PM
    http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-Configure-a-basic-Instant-mesh/ta-p/205027
    HOW TO DEPLOY IAP MESH IN 4.1
    Use following steps to deploy mesh network in IAP4.1:
    1. Put all IAPs in a wired switch, make sure VC key and configuration has been properly synchronized, and make sure country code has being configured; # Configure a new SSID and delete factory default SSID
    2. Turn off ‘extended-ssid’ and reboot the IAP cluster;
    3. Move one of the IAP to the remote site, without wired uplink it will become mesh point.
  • 3.  RE: how to configure mesh in iap 207
    Posted Aug 13, 2017 03:11 AM
    How to turn off Turn off ‘extended-ssid’
  • 4.  RE: how to configure mesh in iap 207
    MVP
    Posted Aug 13, 2017 03:59 AM
    You can change this under System - General. Remember to click the show advanced setting link at the bottom.
