Contributor I
how to enforce the traffic to exit from loopback interface ?
hello all , i have 2 controllers acting as master local , and two radius servers , the two servers configured to receive the authintication request from loopback interfaces of the controller , i reset the controllers and configured them from scratch , the packet became exit from the interface vlan which is connected point to point with the core switch !
how can i enforce the packet to exit from loopback interface ?
Re: how to enforce the traffic to exit from loopback interface ?
