how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
  • 1.  how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
    Posted Apr 15, 2014 09:13 AM
    Is there an option using GUI or CLI?
    Controller: Aruba 3200
    Firmware: AOS 6.3.1.0
    Thanks.
    #3200
  • 2.  RE: how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
    Posted Apr 15, 2014 09:19 AM
    There are options for both CLI and WebUI.  I assume you have a 3200XM if you are already on 6.3.1.0.
    The procedure begins on page 93 of the Release Notes (attached).
    Attachment(s)
  • 3.  RE: how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
    Posted Apr 15, 2014 09:39 AM
    This clear file cleam me out. Currenly download 6.3.1.5 image file.
    Thanks Clembo,
  • 4.  RE: how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
    Posted Nov 07, 2015 05:30 AM
    How to upgrade Aruba 3200 and 7200 WLCs in Master and local scenario.
    Thanks Clembo,
  • 5.  RE: how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
    Posted Nov 07, 2015 09:56 AM
    The release notes have a chapter dedicated to upgrading scenarios.
  • 6.  RE: how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
    Posted Apr 16, 2014 09:27 AM
    Hi Clembo,
    Additional to this is was trying to back up the preconfig im getting denied
    (LAB-Aruba01) #copy running-config ftp: 172.16.0.26 admin password running-config
    Error Copying file: ncftpput /tmp/running-config: server said: Permission denied.
    any suggestions?
  • 7.  RE: how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
    Posted Apr 16, 2014 09:41 AM
    It looks as if admin doesn?t have write permissions to /tmp on your server.
  • 8.  RE: how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
    Posted Apr 16, 2014 09:58 AM
    Was that the controller side who denied the access.?
  • 9.  RE: how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
    Posted Apr 16, 2014 10:01 AM
    Looks like its the FTP server, not the controller.
  • 10.  RE: how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
    Posted Apr 16, 2014 10:18 AM
    Here what on my ftp and change the directory same result
  • 11.  RE: how to i upgrade firmware from AOS 6.3.1.0 to AOS 6.3.1.5?
    Posted Apr 16, 2014 11:24 AM
    Have you tried tftp?   It is sometimes easier as there are no username/passwords/permissions to worry about.   As an alternative, you can download the tech-support logs which includes a copy of the config (inside the techsupport.log file).   You can generate and download these logs from the WebUI directly:
    Maintenance --> Copy Logs --> Download Logs (check include Technical support information)
