Contributor II
how to make certain AP broadcast certain SSID on controller
i was wonder if it possible or not,
 here is my scenario, i have hotel i need to broadcast Guest SSID everywhere but  also i need some floor  Employee , contractor, and voice, but i need everywhere Guest SSID.
(1) for example i have 14 Floor, i need Guest SSID to be broadcast floor 1 to 14
(2) i need 2ND  and 14th floor employee SSID
(3) i need Basement Floor contractor  and Voice SSID
but Guest SSID needs to be broadcast every corner of the building at the same time only some AP broadcast certain SSID but Guest still does.
any idea please
if it is possible from where i can start configuring, i have 7205 x 2 controller Version 6.4.3.1
thanks hope to hear soon
Regard
Tej Bahadur
MVP
Re: how to make certain AP broadcast certain SSID on controller
Hi Tej,
yes, it is possible configuring AP groups with different VAPs and assign APs to those AP groups.
Have a look to this thread it is explained in detail. http://community.arubanetworks.com/t5/Wireless-Access/How-to-use-AP-GROUP/td-p/32828
Regards
Borja
Borja
ACMX #567 //ACCP//CWNA//CWAP
 You can also assign or exclude individual settings to single AP's as well using the AP Specific settings
Configuration > Wireless > AP Configuration ->  AP Specific
Or via CLI...
ap-name "XXXXXX"
virtual-ap "EmployeeVAP"
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
