iPad 2 Slowly stops working on 802.1x network
  • 1.  iPad 2 Slowly stops working on 802.1x network
    Posted Dec 03, 2013 11:24 AM
    I know it sounds crazy, but here is what is happening.
    We have iPad 2's on iOS 7 that can join the 802.1x network then slowly it will not load web pages using Safari to the point where it won't load at all.  Once I switch to our regular WPA2 with a password the iPad works fine.
    Turning WiFi off on the iPad then back on will make it work again for about a minute until it stops working again.
    This worked fine under iOS 6  and below.  I've reset network settings on the device to no avail. This DOES NOT happen on any iPhones that I know of, our 5S and 4S's work okay.  As well as about 200 iPad MInis.  So any other iOS 7 device....
    Doesn't seem like an Aruba issue, but wondering if anyone has seen this on their 802.1x network and a 16 GB iPad 2 with iOS 7.  I'be be curious if this is seen elsewhere.
    I've attempted debugging on the Device, but nothing out of the ordinary came up when it stopped loading pages...
  • 2.  RE: iPad 2 Slowly stops working on 802.1x network
    Posted Dec 03, 2013 11:28 AM
    I forgot to mention we are running 6.3.1.0
  • 3.  RE: iPad 2 Slowly stops working on 802.1x network
    Posted Dec 03, 2013 12:43 PM
    Is it just safari?  Have you tried another browser like Chrome?
  • 4.  RE: iPad 2 Slowly stops working on 802.1x network
    Posted Dec 04, 2013 09:09 AM
    I haven't tried another browser. and I will also take a look at the datapath.   Can I look at the datapath for just that user?
  • 5.  RE: iPad 2 Slowly stops working on 802.1x network
    MVP EXPERT
    Posted Dec 04, 2013 09:11 AM
    Try "show datapath session ip-addr xxx.xxx.xxx.xxx"
  • 6.  RE: iPad 2 Slowly stops working on 802.1x network
    Posted Dec 04, 2013 09:14 AM
    Thanks I will try that when i get a moment and post my results.
    Chad
  • 7.  RE: iPad 2 Slowly stops working on 802.1x network
    MVP EXPERT
    Do you see anything in the "show datapath session" when attempting to generate some traffic?
