iPhone and iPAd problems joining to Wifi (Captive Portal Guest) after sleep
  • 1.  iPhone and iPAd problems joining to Wifi (Captive Portal Guest) after sleep
    Posted Oct 31, 2017 03:25 PM
    Hi
    Customer has 7210 with 6.4.2.8
    There is a problem reported : if device is 'sleeping' 0,5-2h after its waked up it wont join back to Guest Wifi.
    Any suggestions how to identify where is the problem and how to fix it?
    Any known issue available with fix?
    Br - Thanks
    Juha-Pekka
  • 2.  RE: iPhone and iPAd problems joining to Wifi (Captive Portal Guest) after sleep
    Posted Nov 01, 2017 02:35 AM
    i believe this is a known issue due to how apple wifi function with security considerations
  • 3.  RE: iPhone and iPAd problems joining to Wifi (Captive Portal Guest) after sleep
