is channel state dependent packet scheduling supported in a controllerbased setup?
Hi all,
i'm pretty new to Aruba wireless solutions and I need some help in answering an RFP. I would like to know if channel state dependent packet scheduling is supported on a controller base WLAN setup or if there is any other mechanism to improve the overall increase in throughput?
Thank you in advance for your help.
