issues with IP mobility with 6.3.1.2.
  • 1.  issues with IP mobility with 6.3.1.2.
    Posted Feb 05, 2014 02:14 AM
    I have a working IP mobility setup in 6.2.1.4. When i upgrade to 6.3.1.2 my IP mobility is not working. I see the HAT table is fine. I am new IP mobility ? May i know what i am suppose to check.
    6.2.1.4  working fine - output
    5.5.5.2 is the client IP address
    4306) (config) #show ip mobile trail 5.5.5.2
    Station location trail list, 2 location(s)
    Master-AP on switch 172.5.0.1 Station 5.5.5.2
       Roaming Status: Home Switch/Home VLAN, started Wed Feb  5 14:28:36 2014
       Local VLAN 5, ip-mobility/00:1a:1e:57:a6:e0/g
    Local-AP on switch 192.168.10.1 Station 5.5.5.2
       Roaming Status: Mobile IP Binding (Away), started Wed Feb  5 14:40:49 2014
       Local VLAN 2, ip-mobility/00:24:6c:25:5a:a8/a
    Please advice what i am suppose to check or configure on 6.3.x if required ?
  • 2.  RE: issues with IP mobility with 6.3.1.2.
    Posted Feb 08, 2014 10:37 PM
    i Was able to resolve the issue myself thank you.
  • 3.  RE: issues with IP mobility with 6.3.1.2.
    Posted Feb 09, 2014 12:42 AM
    Can you let us know what you did to resolve your issue?
  • 4.  RE: issues with IP mobility with 6.3.1.2.
    Posted Feb 09, 2014 07:55 PM
    I added all the controller's IP address participating in active-domain to HAT Table.
