multiple vlan on captive portal issue
Hello, I'm new to the board as we just procured our first Aruba controller.  We're setting up a captive portal and I have 5 VLANs configured.  The first VLAN I am using is for the controller, and my goal is to use the other 4 VLANs for the captive portal.  I have successfully used each of the 4 VLANs on the captive portal individually, but when I atttempt to use multiple VLANS on the portal by adding a 2nd, 3rd, or 4th VLAN to the portal, any device that obtains a DHCP address for one of these additional VLANs cannot access the portal authentication page.  I'm not sure what I'm missing, hoping someone here has successfully configured this and can help me out.  Thanks!
Re: multiple vlan on captive portal issue
Go to Configuration> Advanced Services> Stateful Firewall.  Enable "Alow-tri-session with DNAT" and click on apply.
Here is the description of the feature in the user guide - "
Allows three-way session when performing destination NAT. This option should be enabled when the controller is not the default gateway for wireless clients and the default gateway is behind the controller. This option is typically used for captive portal configuration"
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Frequent Contributor II
hi
how did you add the other vlans to the captive portal ? did you use:
vlan-name "captive-pool" pool
vlan captive-pool 3-6    ; where 3-6 are vlans numbers
then you have to add this pool (captive-pool) to the guest VAP;
wlan virutal-ap "guest-ap"
vlan captive-pool
please note that it is recommended that the MC is the DHCP server for the guest/captive portal users.
then you have to create 4 DHCP servers for vlan 3,4,5,6
interface vlan 3
interface vlan 3 ip address 192.168.200.1 255.255.255.0
ip nat inside
interface vlan 4
interface vlan 4 ip address 192.168.201.1 255.255.255.0
ip nat inside
interface vlan 5
interface vlan 5 ip address 192.168.202.1 255.255.255.0
ip nat inside
interface vlan 6
interface vlan 6 ip address 192.168.203.1 255.255.255.0
ip nat inside
ip dhcp pool "guestpool3"
default-router 192.168.200.1
dns-server 208.67.222.222 208.67.222.220
network 192.168.200.0 255.255.255.0
ip dhcp pool "guestpool4"
default-router 192.168.201.1
network 192.168.201.0 255.255.255.0
ip dhcp pool "guestpool5"
default-router 192.168.202.1
network 192.168.202.0 255.255.255.0
ip dhcp pool "guestpool6"
default-router 192.168.203.1
network 192.168.203.0 255.255.255.0
service dhcp
have you tried something like this ?
Thanks for the quick reply, cjoseph.  That didn't work for me.  Regarding the description you posted, my controller is the default gateway for all of the VLANs
Take CJosephe solution he is the expert :)
Allright.  You might need to pick one of the ip addresses on the user vlans and make it the "ip cp-redirect-address" ip on the controller.
Choose on the of the VLAN ip addresses on the controller that the user will be using:
config t
ip cp-redirect-address <ip address of controller on one of those vlans>
You also need to be careful, because the controller's internal DHCP server is only rated for 512 DHCP leases maximum.  After that you might have to use an external DHCP server to serve your addresses.
Here's the relevant parts of my config:
vlan 180
vlan 186
vlan 187
vlan 188
vlan 189
vlan-name CCMPool pool
vlan CCMPool 180,186-189
interface gigabitethernet  1/3
description "GE1/3"
trusted
trusted vlan 1-4094
switchport mode trunk
switchport trunk native vlan 180
switchport trunk allowed vlan 1-4094
interface vlan 180
ip address 10.180.0.2 255.255.0.0
interface vlan 1
interface vlan 187
ip address 10.187.0.2 255.255.0.0
ip helper-address 10.187.0.2
interface vlan 188
ip address 10.188.0.2 255.255.0.0
ip helper-address 10.188.0.2
interface vlan 186
ip address 10.186.0.2 255.255.0.0
ip helper-address 10.186.0.2
interface vlan 189
ip address 10.189.0.2 255.255.0.0
ip helper-address 10.189.0.2
ip default-gateway 10.180.0.1
uplink disable
ip dhcp pool CCM
default-router 10.189.0.1
dns-server 10.25.0.120
domain-name xxx.com
lease 0 1 0 0
network 10.189.0.0 255.255.0.0
authoritative
ip dhcp pool CCM2
default-router 10.188.0.1
dns-server 10.125.0.20
domain-name xxx.com
lease 0 1 0 0
network 10.188.0.0 255.255.0.0
authoritative
512 DHCP maximum?  That's not going to work for me, I'll need double that.  I'll reconfigure to use my internal DHCP server.
I had the cp-redirect-address set to 10.180.0.2
I have a question, but let's start with the basics:
The clients that cannot retrieve the captive portal, do they get an ip address, and can they resolve DNS?  That is required to bring up the captive portal.
Any client that gets a 10.189.0.xx address can get the CP auth page and logon and access the internet.  Any client that gets a 10.188.0.xx address cannot.  Those are the 2 VLANs I have setup on CP.
