nack and ack order changed on 5.0
  • 1.  nack and ack order changed on 5.0
    Posted Oct 15, 2012 06:21 AM
    Hi
    IPhone can get IP address on 5.0 while they can not  get IP address on 6.0. From a packet capture, both DHCP nack and ack are sent from dhcp server in our topology. (Please don't notice much why nack is sent. It makes the thing complex.) DHCP server sends “nack” and “ack” in order toward the controller. So nack is sent faster than ack for IPhone on 6.0 all the time, so they CANNOT get IP address. However, ack is sent faster than nack on 5.0, so they can luckily get IP address.
    That is, the controller changed the order from “ack to nack” on 5.0 when passing through even though the server send “nack to ack” in order. This is our concern and my customer persists.
    Can anyone have any idea why 5.0 changes from nack->ack order to ack -> nack order all the way to the IPhone side?
    I just want to know the difference between 5.0 and 6.0 in this point.
    Nack is broadcast and Ack is unicast. Dose this difference relate to that?
    You may see the attahced packet capture on 6.0. It is captured on controller egress port to the client side.
    OAW4504
    AP105
    MAC authentication
    Regards
    Simon
  • 2.  RE: nack and ack order changed on 5.0
    Posted Oct 15, 2012 07:40 AM
    What is the DHCP server?  Are you using a helper address?
  • 3.  RE: nack and ack order changed on 5.0
    Posted Oct 15, 2012 08:43 AM
    Hi Cjoseph
    Windows 2003 and they use ip hepler address.
    This issue happens only vlan 30 which is same vlan server locates.
    They also set ip helper address on this vlan 30.
    So as you see in capture, one dhcp broadcsast discover and another relaed unicast discover are created from the controller, so we guess nack is created for broadcast discover and ack is replied for unicast discover. This is a feature of this network.
    I forgot a capture attach.
    Regards
    Daisuke
  • 4.  RE: nack and ack order changed on 5.0
    Posted Oct 15, 2012 08:48 AM
    Wrong
    Correct
    another relayed unicast discover
  • 5.  RE: nack and ack order changed on 5.0
    Posted Oct 15, 2012 08:29 PM
    Which code did you move in 6.0?
    I don't see the attachment. could you attach the pcap file? Where did you take these captures?
    Pradeep
  • 6.  RE: nack and ack order changed on 5.0
    Posted Oct 15, 2012 09:05 PM
    Hi Pradeepk
    We use from 5.0.3.3 to 6.1.3.4.
    I couldn't attahc capture first. So i attached screen catprue on 3rd comment.
    Regards
    Simon
    Attachment(s)
    zip
    ipphone1_mark.zip   649 B 1 version
  • 7.  RE: nack and ack order changed on 5.0
    Posted Oct 15, 2012 09:57 PM
    Hi Simon,
    Could you paste the output of "show wlan virtual-ap <name of the virtual AP>?
    Does this issue happens only with I-phones?
    Pradeep
  • 8.  RE: nack and ack order changed on 5.0
    Posted Oct 15, 2012 10:41 PM
    Hi Prdeepk
    The order of nack and ack is not changed for any type of clients.
    PC can get IP address even if nack is recived first for some reasons.
    Only IPhone can't get IP address.
    But it may be clinet story, so we want to focus on nack and ack order issue on 5.0
    I paste show command both 5.0 and 6.0. Attachment is configuration.
    Regards
    Simon
    (OAW-4704) #show wlan virtual-ap MatudoSSID-vap_prof
    Virtual AP profile "MatudoSSID-vap_prof"
    Parameter                                       Value
    Virtual AP enable                               Enabled
    Allowed band                                    all
    AAA Profile                                     MatudoSSID-aaa_prof
    802.11K Profile                                 default
    SSID Profile                                    MatudoSSID-ssid_prof
    VLAN                                            N/A
    Forward mode                                    tunnel
    Deny time range                                 N/A
    Mobile IP                                       Enabled
    HA Discovery on-association                     Disabled
    DoS Prevention                                  Disabled
    Station Blacklisting                            Enabled
    Blacklist Time                                  3600 sec
    Dynamic Multicast Optimization (DMO)            Disabled
    Dynamic Multicast Optimization (DMO) Threshold  6
    Authentication Failure Blacklist Time           3600 sec
    Multi Association                               Disabled
    Strict Compliance                               Disabled
    VLAN Mobility                                   Enabled
    Remote-AP Operation                             standard
    Drop Broadcast and Multicast                    Disabled
    Convert Broadcast ARP requests to unicast       Disabled
    Band Steering                                   Disabled
    Steering Mode                                   prefer-5ghz
    VLAN POOL SIZE                                  0
    WMM Traffic Management Profile                  N/A
    (OAW-4704) # show version
    Alcatel-Lucent Operating System-Wireless.
    AOS-W (MODEL: OAW-4704), Version 5.0.3.3
    Website: http://www.alcatel.com/enterprise
    All Rights Reserved (c) 2005-2011, Alcatel-Lucent.
    Compiled on 2011-04-21 at 13:20:15 PDT (build 28008) by p4build
    ROM: System Bootstrap, Version CPBoot 1.3.0.1 (build 28907)
    Built: 2011-06-24 13:46:21
    Built by: p4build@re_client_28907
    Switch uptime is 56 minutes 25 seconds
    Reboot Cause: Power Failure.
    Supervisor Card
    Processor XLR 532 (revision C4) with 2017M bytes of memory.
    32K bytes of non-volatile configuration memory.
    512M bytes of Supervisor Card System flash (model=CF 512MB).
    Parameter                                           Value
    Allowed band                                        all
    VLAN                                                N/A
    Forward mode                                        tunnel
    Deny time range                                     N/A
    Mobile IP                                           Enabled
    Preserve Client VLAN                                Disabled
    Convert Broadcast ARP requests to unicast           Enabled
    Disable conversion multicast RA packets to unicast  Disabled
    Deny inter user traffic                             Disabled
    AOS-W (MODEL: OAW-4704), Version 6.1.3.4
    All Rights Reserved (c) 2005-2012, Alcatel-Lucent.
    Compiled on 2012-07-23 at 17:11:31 PDT (build 34587) by p4build
    Switch uptime is 3 minutes 55 seconds
    Reboot Cause: User reboot.
    Supervisor Card
    Processor XLR 532 (revision C4) with 2016M bytes of memory.
    Attachment(s)
    txt
    showrunning.txt   21 KB 1 version
  • 9.  RE: nack and ack order changed on 5.0
    Posted Oct 15, 2012 11:00 PM
    Starting from 6.1.3.2 there are following featues enabled by default:
    1. "Convert arp to unicast" ( configure terminal wlan virtual-ap <name> no broadcast-filter arp
    2. surpress arp on VLAN (configure terminal interface vlan <id> no surpress-arp )
    It would be worth trying diabling them one by one.
    Pradeep
