need to move config from 7220 controller to 6000 controller
  • 1.  need to move config from 7220 controller to 6000 controller
    Posted Feb 07, 2017 11:22 AM
    I need to take the backup off a 7220 controller and move it to a M3 Controller in a 6000 Chassis., is this even possible?  with the hardware diferences, will this work?  Is there anydocumentation that is available for this?
  • 2.  RE: need to move config from 7220 controller to 6000 controller
    Posted Feb 07, 2017 11:34 AM
    Thought of a possible work around, can I make the M3 a local off of the 7220, then remove it and promote it to a master?  Is it possible to promote a local to a master?  Doing this for a test lab to vet new OS versions..
    Thank you
  • 3.  RE: need to move config from 7220 controller to 6000 controller
    Posted Feb 07, 2017 11:36 AM
    That is the best way to do it.
    Yes, you can promote a local to a master.
  • 4.  RE: need to move config from 7220 controller to 6000 controller
    Posted Feb 07, 2017 11:41 AM
    Thank you, can you give me the cli command to promote this to Master?
    Thank you
  • 5.  RE: need to move config from 7220 controller to 6000 controller
    Posted Feb 07, 2017 12:06 PM
    Found where I needed to change it, thank you
