Hi everybody,I have 620controller,I want to upgrade its IOS using USB,i am try to upgrade the ios using following command
copy USB:AOS.7_43819 system:partition 0
but its showing erorr file not found.
Can some body help in checking this problem.
From AirHeads:
format the usb drive i.e. in vfat format, then copy the firmware image on it.When the controller is then in cpboot> prompt, you can load the image from external USB viacpboot> bootf 1:1 arubaos_72xx_6.2.1.4_40075
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/650-ArubaOS-upgrade-from-USB/td-p/94940
http://community.arubanetworks.com/aruba/attachments/aruba/unified-wired-wireless-access/5703/1/network-storage.pdf
