Occasional Contributor I
"aruba_start_scan_ol 753 Issue scan failled" logs
We are seeing the below KERNEL logs in our controller.  Wondering if anyone has seen this before and knows what it is.  We are seeing about 2000 of these logs in the last hour between 9 AP's.
Controller: 7210
OS: 6.4.4.10
AP's: AP325
"Dec  2 15:42:31  KERNEL((ap-name@(ap-ip): [1622731.262686] aruba_start_scan_ol 753 Issue scan failled"
Any feedback will be appreciated.
Re: "aruba_start_scan_ol 753 Issue scan failled" logs
You should open a tac case.  That does not look familiar.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hopefully this helps someone down the line.  Below is the TAC response we got for this issue.
"got an update from the development team that the log message is not critical and it will not impact the performance of the AP. The reason of the message is scanning cost time is longer than expected, which is most possibly caused by interference in air."
