with the introduction of the AP-203RP i started reviewing our master/local config. For cap's there is no issue. For rap's...
I noticed the rap whitelist is replicated from master to local. But the rest of the config is not. I need to manually define an address pool on the local?
Rap's are typically terminated on the master controller (as in our case). But do they also follow the LMS group configuration? Then i assume the missing address pool is preventing the rap to be terminated on the local controller (since the primary lms ip is the one for the local controller).
I've also read that to prevent rap's from not booting when a the master controller is down, i need to provide the aruba-master dns name with two A records?
