resetting lab controller
  • 1.  resetting lab controller
    Posted Apr 24, 2013 08:54 AM
    All,
    Looking for the best way to reset a lab environment controller to a "gold" config. Would like to write a script to automatically load a known good config in case someone overwrites the startup config. Can we save a config file to flash and then load it?
    thanks,
    Kevin
  • 2.  RE: resetting lab controller
    Posted Apr 24, 2013 09:02 AM
    Whatever you save to flash (copy running-config flash: <filename>) survives a write erase all, but if someone deletes it, it will be gone.
