Contributor II
split tunnel on wired port
Hi
im trying to configure a wired port to split tunnel the traffic. Is there a best practice guide to follow in this case?
I also want to change the role when connecting as a wired client, i dont want to use the "authenticated" role in this case
regards
Carlos
Re: split tunnel on wired port
Is this for a remote access point, aka RAP?
Zach Jennings
Retired Employee
Download the Virtual Branch Network VRD from the link below and go to page#159 - Task 6 - Configure Wired AP and Wired Port Profiles
http://www.arubanetworks.com/pdf/technology/VBN_VRD.pdf
Hope it helps !
HT
HT
Valued Contributor I
Try something like this, but do read the VRDs too...
ap wired-ap-profile "split-tunnel-port"
wired-ap-enable forward-mode split-tunnel
switchport access vlan x
ap wired-port-profile "split-tunnel-port-rules"
aaa-profile "ROLE-WITH-SPLIT-TUNNEL-RULES"
ap-group "YOUR-GROUP"
enet1-port-profile "split-tunnel-port-rules"
The bits in capitals obviously you need to work out!
Kudos appreciated, but I'm not hunting! (ACMX 104)
