MVP
Re: surface device disconnection issues
All AOS with AP3xx should be affected by this particular issue.
rx-ampdu config parameter exists in AOS 6.5.4.x only, there is no other
workaround.
The fix will be propogated to all currently supported AOS versions 6.4,
6.5, 8.x
*SHAWN ADAMS*
*PRINCIPAL NETWORK ENGINEER |**ACMP/ACCP/CWNA | **CEUR**
*T: +49 (0) 151 1265 4997 | M: +49 (0) 151 1265 4997
Baumschulenallee 21-22 | 30625 Hannover - GERMANY
*ARUBA NETWORKS****www.arubanetworks.com*
Shawn Adams
Aruba Networks Customer Advocacy
Thanks Shawn - any ETA?
MVP
I will update this thread as soon as we have exact target release and dates.
*SHAWN ADAMS*
Shawn Adams
Contributor II
Thanks for the feedback Shawn.
Contributor II
I (sort of) apologize for the cross post. I have what appears to be a very similar, if not identical issue with iPad4's. I did create a new post (Link) but noticed this command does not seem to work in a controller environment (v6.5.3.2). Either I got the syntax wrong, or it's only for IAP.
Any further advice?
All,
I have been told that Aruba TAC has published a fix for this issue Bug ID 157287.
New firmware was released this week - upgrade to version: 6.5.3.3 or 6.5.4.2
Thanks all for the help and suggestions along the way :)
Cheers,
Aaron
Will it be available in 6.4x? I just checked the release note of 6.4.4.16 and can't find this bug fix.
Contributor II
I'm told it's fixed in 6.4.4.16, but as yet, the release notes haven't been updated with the bug fix information.
Any customers apply the bug fix and see this issue go away?
We're running 6.5.4.2 and not quite sure that some of our users aren't reporting the same problem.
Contributor II
We upgraded from 6.4.4.11 to 6.4.4.16 last night. We've been experiencing the Surface drops on quite a few devices - Will report back in a few days once we've had time to verify client behaviour.
