Re: surface device disconnection issues
danderson79 wrote:
I'm told it's fixed in 6.4.4.16, but as yet, the release notes haven't been updated with the bug fix information.
https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Command/Core_Download/Default.aspx?EntryId=27397
6.4.4.16 release notes have been updated with the bug fix:
Sorry, the patch did not make 6.5.4.2. It is in 6.5.4.3.
Sorry I retract my previous post. Looks like this fix did make 6.5.4.2. My mistake.
MVP
Please bear in mind, this fix is for one specific issue that might occur in conjunction with Surface Pro devices.
Shawn Adams
Aruba Networks Customer Advocacy
It seems unlikely that the bug is purely surface-specific, based on our troubleshooting and a few other customers reporting similar problems.
philliplyle wrote:
That seems unlikely, based on our troubleshooting and a few other customers reporting similar problems.
The fix in the release notes above is a "narrow" fix, in narrow circumstances.  If everyone would post their TAC case numbers in this thread, we can start defining problems and sorting them into their proper buckets.
Hi Guys,
I can confirm that after two weeks running with the new firmware and disabling the workaround, that this issue has been resolved for our site.
We have around 50+ Surface Books running happily on our wireless with no disconnection issues.
Cheers,
Aaron
philliplyle,
Please clarify what you are seeing, because this thread is about surface disconnection issues.  If it is about something different, or additional, let's open up another thread so that it can get the attention it deserves.
TAC case #5322484848
The exact same symptoms as the OP.   The bug fix release notes don't specifically reference that this is a surface only problem/fix.  We have a much larger environment, and have seem a client mix exhibit the described behavior (Mac, iPhone, Android, Windows), where they remain associated but don't pass traffic for a period of time to a particular AP.   Our senior TAC engineer seemed to think it was applicable.
It's still possible it may have also solved our problem, but it's just harder for us to tell  quickly with 8500 concurrent devices connected, as reports don't always make their way back in a timely fashion.  I'm glad the OP at least has reported an improvement, as it gives us hope.
Okay.
Then it is not a surface-specific issue, then.  It is something larger.
